So my 07 is finally in the shop getting a remanufactured engine put in.
Engine failure due to pushrod bearing going bad.
In the oil pan there was a lot of metal bits.
The re-manufactured engine doesn’t come with the timing cover/oil pump assembly.
The mechanic is telling me we shouldn’t re-use the old timing cover because metal bits could have gotten pulled into the oil channels and he isn’t sure if it can be cleaned thoroughly.
A new one is another $1200 I don’t really have.
So my question is, can I re-use the old timing chain cover/oil pump assembly?
Can it be cleared of any metal shavings that might have found there way in there?
Thanks for any info
Thanks for any info
