1ATony
1991 - 2000 Jeep Cherokee Exhaust Manifold 2.5L
Our aftermarket manifolds are some of the highest quality replacements on the market!
If your vehicle's exhaust is getting loud and the exhaust noise is coming from under the hood or engine then you may need to fix a cracked exhaust manifold. Replacing a broken manifold is easiest with a direct replacement manifold that will fit correctly and bolt up to you original engine and exhaust system. This manifold is a direct fitting replacement.
This Tubular Steel Exhaust Manifold is a new, aftermarket replacement part. It is a direct bolt on and has been designed to eliminate the faults of the original design. Designed for use with all emissions and non-emissions vehicles.
Specifications
Direct replacement
Replaces original manifolds that are cracked from thermal expansion and contraction
Corrosion resistant
Strengthened and redesigned in the vulnerable areas of failure
Now you can buy a high quality exhaust manifold that is built to strict quality control standards and has substantial cost savings over a dealer unit. REPLACE your broken, warped, or cracked one now with this great fitting, exhaust manifold.
Backed by manufacturer's limited LIFETIME warranty. For as long as the original purchaser owns the vehicle, in the event this manifold should fail due to manufacturing defects, we will REPLACE the part free of charge. Warranty is limited to replacement cost only (excludes shipping charges). Failure due to improper installation, or improper use is not covered. Please keep your invoice for proof of this warranty.
This part replaces:
HOLLANDER #: 327-1209T
FREE SHIPPING|GREAT QUALITY|NO HIDDEN PACKAGING FEES
