1998 Jeep Wrangler Sport-4.0 FOR SALE
agpride
1998 Jeep Wrangler TJ 4.0L, Inline 6cyl, 242ci-OHV, 3-Spd. Automatic 32RH Transmission
Aftermarket Build Sheet as follows:
Rock It – Hi Flow 58mm Throttle Body & 3/8” Throttle Body Spacer
Banks Power – Exhaust Manifold [Life Time Warranty], Monster Exhaust System [Life Time Warranty],
Ram Air Intake System [Under Warranty Until June 2012], Banks Air Filter [Life Time Warranty]
Random Technology – Catalytic Converter
MSD – Offroad 6 Ignition Control & Super Conductor Spark Plug Wires
Accel – Ignition Coil [42000 volts @ 1.0 ohms], Cap, & Rotor
Champion – Spark Plugs
Optima Battery – Yellow Top Battery [870CA, 750CCA]
New Century Manufacture – Battery Hold Down [billet aluminum]
AGR – Power Steering Box, Pump [1500 PSI-4 gal.], & Cooler
Tom Woods – Extended rear Drive Shaft [universal joints -Life Time Warranty]
Advance Adapters – Slip Yoke Eliminator Kit
Skyjacker – Transfer Case Shifter Correction Bracket & Steering Stabilizer
Warn – front and rear Bumpers, Rock Sliders, 6” Lights [100,000 candle power-770 feet],
Warn -Winch Plate, Grille Guard, Steering Box Skid, Fuel Tank Skid, ¾” front D-rings [6,000 lbs.],
Warn- Rear Shackle Bracket with ¾” D-ring [6,000 lbs.]
Skid Road Offroad – Radiator Guard
Bushwacker – Fender Flares [4 ¾ pocket style]
Huskey Liners – front and rear Floor Liners
Mean Green – Starter & Alternator [90 Idle Amps-200 Max Amps]
Aluminum Entry Guards
McGuard – Lug Nuts [locking]
American Racing – Center Caps [stainless steel]
Mickey Thompson – MTZ Radial Tires [33x12.5x15]
Pro Comp – Series 51 Rockcrawler Wheels [15x10, 5 on 4.5, 3.75 backspace]
Mopar – Speedometer Gear [34 teeth]
Solid – HD 44 rear Axle Assembly [Life Time Warranty]
Solid - front and rear Differential Covers [Life Time Warranty]
ARB – front and rear Air Lockers & Air Compressor [CKMA12]
Precision Gear – front and rear Ring and Pinion [4.10 ratio]
Wilwood – rear Disc Brakes & Brake Pads
Goodridge – rear Brake Lines [stainless steel braid & fittings with vinyl hose]
Rubicon Express – 4.5” Extreme Duty Long Arm Kit [Limited Life Time Warranty]
Rubicon Express - 4.5” Monotube front and rear Shocks [Limited Life Time Warranty]
Currie Enterprises – Tie Rod & Drag Link
Alloy USA – rear Axle Shafts [35 spline] & Ring and Pinion Overhaul Kit
Classic Tube – Transmission Cooler Lines, Brake Lines, & Power Steering Line [all stainless steel]
Pioneer – Super Tuner III am-fm-cd, GM-X314 Amp, 4x6 front Speakers, rear 8” Full Range Box Speakers
Audiovox – Alarm System, Shock Sensor, and 2 spare Remotes
Power Stop – front Rotors [slotted]
Hawk – front HPS Brake Pads
Teraflex – Emergency Brake Cables
JKS- front Adjustable Coil Over Spacers
M.O.R.E. – Torsion Rubber Motor Mounts
Flex-A-Lite – High Performance X Treme Electric Fan & Transmission Cooler [12,000 GVW]
Addco – front Sway Bar [1-1/4” dia.] & rear Sway Bar [3/4” dia.]
Unichip – Performance Computer Module [Under Warranty until 12-24-11]
Bestop – Soft Top Sailcloth with Tinted Windows [black diamond]
Hesco – Water Pump & Thermostat Housing
Robertshaw – Thermostat [195 degree]
Rugged Ridge (Omix-Ada) – Bug Screen & front Hub Assemblies [Life Time Warranty]
Superior – front Axle Shafts [30 spline / Life Time Warranty] & front Axle Tube Seals
Prothane – Polyurethane Transmission Mount & Body Mounts
Northern Factory – Aluminum Radiator & Radiator Cap [20 lbs. high pressure]
Smittybilt – Locking Hood Latches
Crown - Oil Pan, Oil Pan Gasket, & Rear Main Bearing Seal
Bosch – Wiper Blades
Stainless Steel Hardware [used for some applications]
POR-15 Rust Preventative [have been applied to the underneath of the Jeep]
OTHER:
NO Back Seat [replaced with a custom made carpeted platform for additional cargo space]
Warn rear bumper designed to fit Warn rock crawler tire carrier
Full Metal Doors with roll up Glass Windows
Dual Airbags
Transfer Case [NP 231]
Fuel Tank [19 gal.]
Reclining Cloth High-Back Bucket Seats
Locking console and glove box
Tilt wheel and Power steering
Fluids being used:
Fuel – 87 Octane
Motor Oil – Pennzoil [10W30 Synthetic]
Gear Oil – front Lucas [80w90] & rear Wolfshead [80w90]
Power Steering Fluid – Redline [Synthetic]
Coolant – Be Cool [300,000 mile coolant]
Automatic Transmission Fluid and Transfer Case Fluid – Valvoline [ATF+4 Synthetic]
Brake Fluid – [DOT 3]
·Flushed Transmission Fluid and Replaced Gasket [every 30,000 miles]
·Changed Transfer Case Fluid [every 30,000 miles]
·Changed Front and Rear Axle Fluid [every 30,000 miles]
·Flushed and Replaced Coolant [every 45,000 miles]
·Changed Oil and Oil Filter with AC Delco Filter [every 3,000 miles]
·Changed Brake Fluid at 104,388 miles
·Changed Power Steering Fluid at 106,745 miles
Additional parts and accessories will be included if wanted, FOR FREE, with purchase of Jeep:
2-NEW Thrust Washers [for Dana 30 axle]
1-NEW front end Federal Mogul Ball Joint
2-NEW Rubicon Express Shock Mounts
NEW Rear Rubicon Express Track Bar Bracket
NEW Rear Rubicon Express 24” Stainless Steel Brake Line
2-NEW Federated Auto Parts 3/16”x60” Brake Lines
CST Radiator Cap [18 lbs.]
1-NEW Pro Comp Series 51 Rockcrawler Wheel [15x10, 5 on 4.5, 3.75 backspace]
1-IPF Headlight Insert
1-IPF X51 Fatboy Bulb
NEW Polished Stainless Steel Tailpipe Tip with Clamp
NEW Huskey Liners [front floor liners]
Empire Cover-outdoor cover [Limited Lifetime Warranty]
Bestop Vinyl Window Cleaner, Soft Top Cleaner, and Soft Top Protectant
Extra bottles of fluids
Yakima Bicycle Rack [for a spare tire]
3-McGuard Lug Nuts [locking] for a Spare Tire
Spare Keys and original Remote for alarm system
1-NEW front side turn signal Light Bulb
Have some Original Hardware if wanted as well.
·Have ALL Receipts of parts and work done, Warranty/Registration Cards, Installation Instructions/Manuals, and original OEM Build Sheet to give.
·ALL Warranty and Registration Cards were mailed in or submitted on-line.
·ALL parts were purchased between 2006 and 2010
·A Certified and Professional Mechanic did ALL work.
·I purchased the Jeep NEW from the factory thirteen years ago, therefore there has only been one owner. The Jeep has never been in an accident; very well maintained, always covered and has never been off-road, seriously. MUST SEE IT TO BELIEVE IT!
·Current Mileage – 109,266
·Inspection & Emissions – Expired January 2011
Price:
$15,000.00 (OR BEST OFFER)
Cash in hand Only
Buyer is responsible for current inspection & emissions
Buyer is responsible for vehicle pickup
Contact Information:
Aaron
Pittsburgh, PA
(724) 265-8495
