1ATony
	1999 - 2004 Jeep Grand Cherokee Water Pump (AIRTEX) for L6 4.0L
This water pump is a new replacement part that has the following specifications.
Specifications
New not remanufactured
Replaces one of many dealer part numbers including: 5012366AB, 5012366AC
Built to strict quality control standards
No core charge
Includes gasket
Fits the following Jeep engines as listed:
L6 4.0L
Your water pump is a major component of your engine cooling system. If the water pump fails, the engine will overheat causing it to shut down. Water pumps have an indicator that tells you when they are going bad. There is a small hole in the water pump right under the shaft in the middle that the pulley bolts to. As the water pump's bearings wear out coolant seeps by them and leaks through this hole. If you notice a few drops of coolant under the front of your engine this is an indicator your pump is failing. If a water pump fails it will cause engine overheating, and possibly further engine damage. If you have noticed little drops of coolant under the front of your vehicle then inspect the bottom of the water pump to see if it is dripping out of the indicator hole. If your water pump is the problem, then this part is for you. Replace your broken or leaking water pump now with this great fitting replacement part.
This part replaces:
HOLLANDER #: 324-00845
OE #: 5012366AB, 5012366AC
FREE SHIPPING ON ALL ORDERS IN THE LOWER 48 STATES. NO HIDDEN PACKAGING FEES
