Procrastinator_j
Bought a Used 1990 Wrangler with the 4.2 L6 258. Three weeks after purchase lost most of the oil pressure so I decided to rebuild the Motor. After getting a new crank from a reputable machine shop and buying appropriately undersized bearings, .020 under for Main and Rod, After installing the new Mains and lubing them up with assembly lube real nice as i set the Crank in it seems to bind up on the #1 main bearing by the rear main seal. after checking multiple retailers i am sure i have the correct Bearing set. I also checked the old bearings with the old crank and am realizing this is happening with the old ones as well. Its my impression that the bearings should fit nice and snug around the Journal but also with lube should allow the crank to spin and not bind with the Bearings. I am not sure what is wrong.
Main Bearing Set
Unusual Activity Detected - Free Shipping on Orders Over $99 at Summit Racing
			Main Bearing Set
