WranglerRoller
RE: mc 2150 crank case vent
:? My 87 Wrangler sounds like it is remaining partially in 4wd when in 2wd. I can shift into 4wd and you can feel the 4wd kick in and the "4WD" light illuminates. When I shift into 2wd the "4WD" light goes out and you can feel the 4wd at least partially disengage. There are a lot of clanking sounds at low speeds coming from the front end. When I put the Wrangler up on jack stands I was able to put a vacuum pump on the shift motor and get the axle out of 4wd completely. However, when I put the Wrangler back on the wheels and reconnected the vacuum hoses I had the same problem. When I took the Wrangler to NJ state inspection they put the Wrangler on a dyno and the car tried to jump out of the blocks, indicating the Wrangler was in 4wd when shifted to 2wd. I can find no information on how to troubleshoot the shift motor, linkage, or shift vacuum system. Anyone know where I can get such info?
