54 cj3b 4.3 sm465 build
54cj3b
Sorry some picts may be blurry or distorted never claimed to be photographer :D
First day 3b got home in 2004
Beginning of tear down
After pulling engine this is what I found
back to tear down
After the tear down I bought a 134 F head and rebuilt it
After building the f head I changed my mind and bought a 4.3 along with a sm465
After repairing the body I put a bed liner on the tub before adding 1/4 in alum diamond plate Cutting and bending this stuff was a nightmare After going through 4 grinders 2 saws all and a jig saw I found it cuts like butter using a circular saw with a 12 tooth carbide blade used to cut plywood go figure
Added flairs from a S-10 blazer on rear wheel wells
bed lined whole inside of tub
installed 4.3 along with sm465
installed fuel tank
I painted the body panels but they came out like crap so i will be stripping them and redoing them
here are a bunch of goodies my wife let me order to finish my jeep
I went with gray seats
cant wait till these goodies get here
one thing I would do different next time is use the sm420 its not as bulky with the 465 be prepared to cut out the center hump on floor
trans sits about 6 inches above the floor inside jeep
now going to fab up a floor pan like this
Almost forgot with my progress added a wood floor to the rear tub floor
and roll bar
also window frame
6 years and still going but considering I was down 4 years with cancer think I'm getting back on track
My goal to have finished is April 2011
this is the color I'm going with
Burgundy pearl candy
I took the liberty of attaching your photos ;)
Man that things looking good.
Well between last night and today I finished mounting the seats
cleaned up wheels and painted them
and yes the headers headers came now time to send out to be heat coated
and I see I got a better shot of the floor in tub
Ok....I see a what I believe is a Spicer 18 (best of my knowledge) with what appears the be a drive line either: 1) brakes or 2) parking brakes. What wuz it for? Did it work well? Is is some sort of "stock" set-up (I've never seen this on an 18)? Is it still laying around your garage?
used the spicier18 transfer case that was beefed up with 20 gears along with the parking brake it was original and sold the T-90
Love the build, but honestly you lost me with the diamond plated sides. If you like them, the do it.
this build is exactly what I want to do, I got to wheel a 46 cj2a couple weeks back, pretty much bone stock except for front and rear lockers and 34" ltbs... Most fun I have ever had wheeling. but it definatly needed deeper transmission gears and looks like you got that covered. Don't mean to hijack, and please disregard the goofy passenger, it was a posed picture :roll:
The main reason for the diamond plate is because of all the rock out here and its probably going to be on its side a lot that way it gets the abuse not the tub and always can replace when it gets to the point I cant stand it
nice 2A yes there fun build it right you'll out perform the newer ones lol
oh hell ya out perform, hard to see in the back ground of that pic, but it's a red TJ on 1 tons with 39" iroks and I got stuck less than him, in fact the one time I did get stuck was because I landed on a rock that was pressing on the clutch linkage and I could not get the clutch to disengage.
The body on that 2a was pretty beat to begin with. I was just saying the diamond plate was not my taste, I personally would have just use aluminum sheet.
For $60. a 4x8 sheet You would use it also lol found it at a recyclers Goes for almost $280. a sheet was going just polished then I got this good deal who am I to say no:D Just a FYI its no picnic cutting it
OK headers are back was going to install them when I found out The manifold gasket is the wrong one going to pick up the right ones tomorrow
but I got the grill on and radiator installed
and both brake master cylinder and clutch master cylinder installed today
Still awaiting the lift hope it gets here soon
did I mention I'm going round 2 on ordering more goodies:funny: :beer:
Did alot of wiring and ran speed o cable and few other things today no new picts yet but maybe tomorrow
Dana 44 rear 538 locked front 27 538 ,as for suspension stock springs with a black diamond 2.5 add a leaf and shocks soon as it gets here , been waiting impatiently for it to arrive it will have a nice flex but ride like a brick lol
well my new gaskets came so Ill put on headers today and finish wiring
Installed headers today look good , Had to trim inner fender wells also got left fender installed
Well today I finished the gauge cluster
Also got front part of the lift in along with new shocks
Now I sit till the back part of my lift shows up next week
found speedometer cable to be broken today (need to order a new one)
jacked back 1/2 of jeep up placed stands under frame in front of leafs PB all rear leaf hardware getting it ready to tear down and install rear lift busted loose all u bolts via impact gun boy I love this thing placed 2 more stands under axle to support it now a long day to come tomorrow ,
