C Crew11 New member Feb 18, 2008 #1 I've installed a RE 2.5" lift- it comes with brake line extensions but does not mention anything about the ABS wires to the front wheels. What options do I have with these things? Thanks. '95 Sahara
Bounty__Hunter Super Moderator Feb 19, 2008 #2 Is there not enough slack in the lines with that small a lift? I'd pull more wire loose from the frame and gain length from the frame to the axle.
