Allen's Offroad
Good day all.
Allen's Offroad is proud to team up with the guys at Battle Born Wheels. bringing you an affordable Steel beadlock wheel for the toughest terrain. Click an image below to see them on the site. Currently backordered on all 15", the 5x4.5 17", and all 4.5" beadlocks. Should be coming in late Spring. Spend your tax refund on a set of steel beadlocks and be glad you did.
Get in line now for the next shipment. Backorder today.
The Gatekeeper of any trail controls access or entry. Sometimes it might be subtle, while other times it may be one of the most difficult obstacles on the trail. On a local trail in Northern Nevada, there is access to one of the nastiest Gatekeepers that many have ever attempted. Lucky Canyon's Gatekeeper is unforgiving and refuses entry to anyone scared of body damage. The Gatekeeper is the entry point much like this wheel. If you are looking to get some real beadlocks at a great price then you've found it.
These classic steel beadlock wheels are made with a 32 bolt outer beadlock ring that clamps tight to the tire bead with grade 8 bolts.
For Offroad use only
NOTE: May need universal TPMS for some applications. Interco’s and Pitbull tires have had some issues due to large tire beads. They are working on some ring spacers to correct this issue. The best tires so far are Nitto’s and Procomp’s but they are not the only tires you can run.
Have a fantastic day!
Allen
Allen
