camcdaniel1
1995 Wrangler 4.0 what turns the fuel pump on /off. I realize the rail PSI is controled by a vac reg. When you trun the key on the pump runs till it builds Psi then turns off. My jeep runs for a few minuates then starts to stumble. I can turn the key off and right back on and it runs fine for few minuates then starts to stumble again. Is there a sensor that turns the pump on and off?
