Eclektq
Just finished up swapping a '94 YJ 4.0 with an AX-15 into a '95 YJ and now on occasion when a let out the clutch I'm getting a LOUD popping coming out of the either the tranny or transfer case. I have the floor plate around the shifter removed so I'm hearing it real clear. All angles as far a pinion, Drive shaft U-joints are perfect. Rebuilt front and rear axles and done by an expert that spec'd out the lash and pre loads on both. The transfer case, 231J was on the AX-5 that I snatched out with the 2.5 and we had to go in and change out the input shaft to mate it to the
4.0...Yay Chrysler incompatibilities!! I'm wondering if the transfer case stabilizing bolt not being there would have anything to do with it. Like I said, It's intermittent and there are no accompanying noises, Grinding, Winding etc. Any input will be appreciated!!
