YJ_ROLLOVR
Hey Jeepers, I have a 93 YJ that I changed the heater core on in Aug 2010, but it doesn't get as hot as it use too. I ran it bypassed from March until August, before changing the core. All vents, controls cables, vacuum valve, thermostat(new 12/2010), water pump(new 12/2010), etc. have been checked, all a operational. But the heat is not as hot as last year. Using a stick thermometer I get 120 degrees at the defroster vents in the window, with the jeep at idle and fan at meduim. This figure should be at least 165 degrees or greater. I have burped it, using my compressor, blew air through it, using a vacuum, and sucked air through it. The only difference is that the old core was copper and the new core is aluminum(new 8/2010). Has anyone experience this or have any additional thoughts... Thanx!!!
