Dear Jeep enthusiasts,
I own a 97' Wrangler 6 cylinder, 5spd. My problem is this. When I go to crank the jeep in the morning it cranks fine, but i usually let it warm up before I start driving. In the warming up process or idling process, the jeep starts to idle really rough. It will sputter while idling like it is fixing to turn off and then every now and then will rev itself up and idle normal. When I don't warm it up and just drive it, it will do the same thing down the road. It will act as if it is fixing to die until I rev it up or shift gears. Its not the temperature sensor because I replaced that. Its not the alternator because I tested it is fine. I have tried cleaning the throttle body plate, fuel injector, and nothing has helped it. Any help would be very nice thank you
