leakimg diff fluid
If you have USA Alloy axles, this would be the mud seal, the stock axle does not use it. I think you want this:
26 Axle Oil Seal 1987-1995 ALL 8121781 $2.99
The link did not work, but go to the YJ section at Morris, front differential/Dana30 and look at #26. I did a write up on rebuilding a wide track Dana30 in the "how to section" and the seal replacement is covered.
Sorry, was just looking at the diagram at Morris, it can be found under YJ, axle front Dana30. The part you listed is the equivalent of #21, intermediate seal. You will need to know the diameter of your axle shafts if they are stock.
I have a friend who owna an ammco across the etreet, I went to get him to order part. There is a 95 wrangler there with a blown engine, has a 44 in front and 8.8 in rear. he is not going to fix it, trying to buy it for parts.
