jackal
I have a 78 Cj7. When I bought it the master cylinder was leaking around the firewall. I replaced it with a rebuilt one. It leaked out around the cover. I replaced it with another one and it leaks, too ,around the cover or "lid". I bled both of them as I usuallly always do on other cars. I also bench bled them. I even bled the front brakes on the Jeep first to align the plunger in the proportioning valve as they say to do in the JEEP BIBLE.
I recently ran across an old Chilton Shop Manual. The BIG book . It says in there to use a clip tool of some sort to hold open the proportioning valve while bleeding. It doesn't show a close-up but it gives an explanation. There are even part #'s for the clips depending on which year model you own.
Has anyone ever run into this problem? If you have let me know.
I really appreciate it.
Later,
Jackal
Later,
Jackal
