firesean3532
Hello all I'm pretty new to this forum. Just got an 1984 CJ7 with a 258 in it. TO give a little background on it. It has a rebuilt motor. New 4 speed. I have replaced the Top, Bikini Top, Duster, New U Joints, New Weber Carb, New output Transfer Case yoke, New Battery, New Negative cable, New coil, New non points distributor, New Spark Plugs, and now a new Motorcraft AutoSpark Ignition Module.
Now my question. Is there a more reliable ignition Module than the Motorcraft Autospark? Do I need to worry about doing the Nutter Bypass?
The problem that I am having is that the Jeep starts, and runs well until warm. Then It cuts off if its at an idle and will not restart for a while. When the jeep isnt starting there is no spark going from the coil, hence the coil replacement. Is there a way to get rid of the electronics without much money or too awful much effort? I though that was what the Nutter bypass did.
Thanks in advanced for the assistance
