Tug-n-pull
I bought my jeep and the dot 3 went somewhere a few times. I did the refill bit. Somewhere between the master and the slave it is doing a vanishing act. Rebuilt the clutch and the garage guy say's he would not change the slave or master as they both look pretty new. No signs of leakage of dot 3 on either. Have driven now with new clutch for a couple of months no problems at all. Yesterday the pressure was gone in the clutch and I had to refill for the 1st time after the rebuild. So today it is worse, pulled into the shop crawled under and the jeep and bleed the system, it is still not back up as good as it was but it is changeing now. Reverce is a bit hard to hit with a bit of grind. Question I can not find any sign of a leak over the whole system, so where does the dot 3 go? Thanks for any help!
Tug
Tug
