bobcat481
Ok.....my oil pressure gauge used to read one line above 40 running down the road, and one line short of 40 at idle. Over the past few weeks, the "range" of the gauge has been dropping, never getting up to 40 even running down the road. My question is, can an oil pump go out slowly, or do I more than likely have a gauge problem? Also, is it possible the the screen is clogged? It gets regular oil changes, so shouldn't be that slugged up. As far a running, it runs and sounds fine. Any thoughts? Thanks
