76quadtrac
Replaced Timing chain and while replacing oil pump gears I noticed the marks, like the ones on the timing gears but the only difference was the marks are on the teeth of the gears? How do I reinstall them? which way should i point them? I have the AMC 401 V8. Oh, you know the one about when you reinstall the distributor assembly after putting new gears in your supposed to find the compression stroke on #1 and install the dist. with the rotor pointing at the #1 cylinder? Ok, we probably all have, It doesn't work :-x The rotor needs to be pointing at the #1 plug wire on the cap. I talked to a lot of people and they all said the same thing and they are WRONG! Point it at #1 on the cap! It took 2 hours and after some thinking, I figured it out. Runs like a champ. Also found out that the original timing was set from the #2 cyl. how it ran,,,?
