poping out of reverse on 87 wrangler
Do you have the 4.2L 6cyl engine? If so my '88 with the same Peugeot BA10/5 transmission did the same thing. It did fine if I held it in reverse. I think the only fix is a rebuild or replacement of the transmission.
Yes has a 4 in body lift if I slam it in reverse it wont pop out I need to look and see if it is hiting and thanks everone
4" body lift???? wow man, you sure that is safe? it seems like any kind of sudden stop and the bolts are shearing off
