Center-Axis
- Innovative design eliminates the need to release, or remove, additional pins or latches before you can remove the fire extinguisher saving valuable seconds in the event of a fire.
- All aluminum construction keeps weight to a minimum while maintaining the strength necessary to ensure that it's right where it should be when you need it.
- All hardware is 18-8 Stainless Steel to prevent corrosion making it perfect for use in boats, 4x4s, and other situations where it is exposed to mother nature.
The mounting base will be completely hole free to allow you the most flexibility in mounting options. You can bolt it down to flat surface, or to a roll cage by using U-bolts if you desire.
As previously mentioned, this is a pre order sale, and we do not currently have inventory ready to ship. All of the vendors are lined up, and as soon as enough orders have been placed to cover the initial manufacturing costs, manufacturing will begin. Based on the orders that have already been placed, we expect to be able to begin manufacturing in approximately 2-3 weeks. Once the manufacturing process has begun, we expect, but cannot guarantee, to be shipping product roughly 6-8 weeks later. In order to compensate the Jeepz members for the long lead times, you can use the coupon code "JEEPZ", "Jeepz", or "jeepz" during your checkout to receive a discount of $15.95 for each quick release mount that you purchase on our website www.center-axis.com. Feel free to share this discount code with others as well. The quicker we receive orders, the quicker we can begin shipping. Once we have received enough pre orders to begin manufacturing the coupon code will no longer be available, and we will post in this thread to let everyone know when the pre order sale has ended.
Below is a couple of 3D renderings of the quick release from the design files. This has been rendered to represent the final product as accurately as possible.
The video below is of the prototype which has been clamped into a vise for testing and demonstration purposes.
If you have any questions, please ask away.
Product Liability Disclaimer and Warranty Information
Every application and installation is unique and cannot possibly be tested by the manufacturer to verify that the installation and operation is suitable for the end users intended purpose or use. The method of installation, orientation, and location of this product are all factors that MUST be considered. When mounting in/on any vehicle, of any type, there is always a risk of injury to the operator or passengers due to loose objects in/on the vehicle in the event of a collision or due to rough terrain. It is extremely important that ALL factors are taken into consideration when installing this product to ensure that if the product fails, the operator and/or passengers cannot be injured in any way as a result of the product failure.
Extreme caution should be used when operating or handling the product as it contains many pinch points and a very heavy spring which could be capable of breaking or severely injuring your fingers, hands, etc. Do NOT let your children play with the clamp.
Warranty parts or product replacement will be handled on a case by case basis. Every product is checked and inspected prior to shipping to verify functionality. However, in the event that you feel that you require warranty service or replacement, please send me a PM within 30 days of receiving your product.
