Baseline 4x4
REP01-RPXD-CS - Replay XD Camera
Beauty is in the eye of Replay XD. It features a hard anodized, rugged aluminum chassis for your rigorous and compelling adventures.
Simple ON and OFF buttons make the Replay XD camera a pleasure to operate. There are no learning curves, button-press-counting schemes, or fragile slide switches to make you wonder if the camera is on or off. Simply turn it ON to Record and turn it OFF to Finish. The built-in LED & Vibration Feedback simply tells you that the button has been pressed.
Display External display option (not included)
Storage microSDHC (up to 32 GB), Duration 1 GB = 30 min
Ports 8 Pin Mini-USB 2.0
-Charge and Sync
microSDHC slot
Power AC Power 100~240 V, 50~60 Hz
Rechargeable Li-ion Battery 3.7 V, 300 mAh*
up to 110 Minute Record Time*
Size 21.4 mm Dia. x 69mm
Weight 30 grams (including battery & microSDHC)
Control Power "On" & Power "Off" Button with Vibration Feedback
Resolution 640 x 480, up to 30 fps
Pixels 1.3 MP CMOS
Field of View 61 Degrees
Lens Cover Replaceable Bezel and Lens Cover
Power Supply 5V +/- 0.5V / 2A
System Requirements: PC Video Playback
Windows Intel® Pentium® processor 300MHZ or higher
Windows® XP with Service Pack 3, Windows 7
1 GB of RAM
USB Port, Mouse
Macintosh PowerPC® G4, or G5 Processor or Intel® Core Duo® or higher
Mac OS X 10.4, 10.5, 10.6 or 10.7
1 GB of RAM
USB Port, Mouse
Whats Included
1 Replay XD Camera
1 FlatMount (Swivel)
1 ClipMount (Tilt)
4 3M® Dual-Lock
1 4GB microSDHC Card
1 USB Cable
1 USB DC Wall Charger
1 USB Car Charger
1 User Guide
2 Decals
1 Silk Camera Bag
1 Ballistic Nylon Carrying Case
1 Camera Safety Lanyard
A fun time ahead of you.
Here is my video that I made using the camera and flat mount base. I am going to test out my short arm suction base today.
Optional Accessories:
REP70-RPXD-SCM-SA - Replax XD Camera Short Arm Suction Base
REP70-RPXD-SCM-LA - Replax XD Camera Long Arm Suction Base
REP70-RPXD-CC480 - Replax XD Camera Clamp
