Allen's Offroad
Good day all.  Huge price reduction on all the Revolution gear packages with Koyo bearing master kits.  See the selection below.  Post, email, or PM for best price.  The normal coupon code does not apply to these prices.
JK packages as low as $453.28 shipped.
TJ packages as low as $380.00 shipped.
YJ Packages as low as $380.00 shipped.
Have a blessed and prosperous day!
Allen
Click image below to order on the site. I am still up loading product. The JK and all of the TJ stuff is there.
Rev-JK-Non-411-K JK Non Rubicon (D44/D30) 4.11 gear package front & rear with Koyo master overhaul kits (Front case required for factory 3.21 ratio only)
Rev-JK-Non-456-K JK Non Rubicon (D44/D30) 4.56 gear package front & rear with Koyo master overhaul kits (Front case required for factory 3.21 ratio only)
Rev-JK-Non-488-K JK Non Rubicon (D44/D30) 4.88 gear package front & rear with Koyo master overhaul kits (Front case required for factory 3.21 ratio only)
Rev-JK-Non-513-K JK Non Rubicon (D44/D30) 5.13 gear package front & rear with master overhaul kits (Front case required for factory 3.21 ratio only)
Rev-JK-Rub-411-K JK Rubicon (D44/D44) 4.11 gear package front & rear with Koyo master overhaul kits
Rev-JK-Rub-456-K JK Rubicon (D44/D44) 4.56 gear package front & rear with Koyo master overhaul kits
Rev-JK-Rub-488-K JK Rubicon (D44/D44) 4.88 gear package front & rear with Koyo master overhaul kits
Rev-JK-Rub-513-K JK Rubicon (D44/D44) 5.13 gear package front & rear with Koyo master overhaul kits
Rev-JK-Rub-538-K JK Rubicon (D44/D44) 5.38 gear package front & rear with Koyo master overhaul kits
Rev-TJ-D35-373-K Jeep TJ & 96-04 Grand Cherokee (D35/D30) 3.73 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D35-410-K Jeep TJ & 96-04 Grand Cherokee (D35/D30) 4.10 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D35-456-K Jeep TJ & 96-04 Grand Cherokee (D35/D30) 4.56 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D35-488-K Jeep TJ & 96-04 Grand Cherokee (D35/D30) 4.88 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D35-513-K Jeep TJ & 96-04 Grand Cherokee (D35/D30) 5.13 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-373-K Jeep TJ 96-02 (D44/D30) 3.73 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-410-K Jeep TJ 96-02 (D44/D30) 4.10 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-410T-K Jeep TJ 96-02 (D44THICK/D30) 4.10 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-456-K Jeep TJ 96-02 (D44/D30) 4.56 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-456T-K Jeep TJ 96-02 (D44THICK/D30) 4.56 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-488-K Jeep TJ 96-02 (D44/D30) 4.88 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-488T-K Jeep TJ 96-02 (D44THICK/D30) 4.88 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-513-K Jeep TJ 96-02 (D44/D30) 5.13 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-513T-K Jeep TJ 96-02 (D44THICK/D30) 5.13 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-373-Late-K Jeep TJ 03-05 (D44/D30) 3.73 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-410-Late-K Jeep TJ 03-05 (D44/D30) 4.10 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-410T-Late-K Jeep TJ 03-05 (D44THICK/D30) 4.10 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-456-Late-K Jeep TJ 03-05 (D44/D30) 4.56 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-456T-Late-K Jeep TJ 03-05 (D44THICK/D30) 4.56 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-488-Late-K Jeep TJ 03-05 (D44/D30) 4.88 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-488T-Late-K Jeep TJ 03-05 (D44THICK/D30) 4.88 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-513-Late-K Jeep TJ 03-05 (D44/D30) 5.13 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-D44-513T-Late-K Jeep TJ 03-05 (D44THICK/D30) 5.13 gear package front & rear with Koyo master overhaul kits (Does not include carrier cases)
Rev-TJ-Rub-456-K Jeep TJ Rubicon 4.56 gear package front & rear with Koyo master kits (Comes with thick gears so no carriers needed)
Rev-TJ-Rub-488-K Jeep TJ Rubicon 4.88 gear package front & rear with Koyo master overhaul kits (Comes with thick gears so no carriers needed)
Rev-TJ-Rub-513-K Jeep TJ Rubicon 5.13 gear package front & rear with Koyo master overhaul kits (Comes with thick gears so no carriers needed)
Rev-TJ-Rub-538-K Jeep TJ Rubicon 5.38 gear package front & rear with Koyo master overhaul kits (Comes with thick gears so no carriers needed)
Rev-YJ/XJ-D35-410-K Jeep YJ/XJ 84-96 (D35/D30 reverse) 4.10 gear package front & rear with KOYO master overhaul kits (Does not include carrier cases)
Rev-YJ/XJ-D35-456-K Jeep YJ/XJ 84-96 (D35/D30 reverse) 4.56 gear package front & rear with KOYO master overhaul kits (Does not include carrier cases)
Rev-YJ/XJ-D35-488-K Jeep YJ/XJ 84-96 (D35/D30 reverse) 4.88 gear package front & rear with KOYO master overhaul kits (Does not include carrier cases)
Rev-YJ/XJ-D35-513-K Jeep YJ/XJ 84-96 (D35/D30 reverse) 5.13 gear package front & rear with KOYO master overhaul kits (Does not include carrier cases)
Rev-YJ/XJ-D44-410-K Jeep YJ/XJ 87-96 (D44/D30 reverse) 4.10 gear package front & rear with KOYO master overhaul kits (Does not include carrier cases)
Rev-YJ/XJ-D44T-410-K Jeep YJ/XJ 87-96 (D44THICK/D30 reverse) 4.10 gear package front & rear with KOYO master overhaul kits (Does not include carrier cases)
Rev-YJ/XJ-D44-456-K Jeep YJ/XJ 87-96 (D44/D30 reverse) 4.56 gear package front & rear with KOYO master overhaul kits (Does not include carrier cases)
Rev-YJ/XJ-D44-456T-K Jeep YJ/XJ 87-96 (D44THICK/D30 reverse) 4.56 gear package front & rear with KOYO master overhaul kits (Does not include carrier cases)
Rev-YJ/XJ-D44-488-K Jeep YJ/XJ 87-96 (D44/D30 reverse) 4.88 gear package front & rear with KOYO master overhaul kits (Does not include carrier cases)
Rev-YJ/XJ-D44-488T-K Jeep YJ/XJ 87-96 (D44THICK/D30 reverse) 4.88 gear package front & rear with KOYO master overhaul kits (Does not include carrier cases)
Rev-YJ/XJ-D44-513-K Jeep YJ/XJ 87-96 (D44/D30 reverse) 5.13 gear package front & rear with KOYO master overhaul kits (Does not include carrier cases)
Rev-YJ/XJ-D44-513T-K Jeep YJ/XJ 87-96 (D44THICK/D30 reverse) 5.13 gear package front & rear with KOYO master overhaul kits (Does not include carrier cases)
Allen
