Some updates/questions after I've had time to clear my head
GaryMB
Re: RE: Lift and tires!!!!!!!
I've been on vacation for a while now (I love central Oregon!), and have, for the first time in quite a while, gone more than a couple days without worrying about how I will continue to build my Jeep. Well since I would like to be able to get to work on the CJ when I get home, I started ordering things again. I think that I'll be going with RE Wrangler 4.5" lift springs and homemade shackle reversal/outboard, whatever dana 44's I come accross first, and the guy at the local 4x4 shop up here recommended Skyjacker Hydro shocks as a good on/offroad shock for an sua application. As for the motor, things had been getting pretty hectic...but now, I've decided that I can live with a stock or slightly modified 4.0L, but don't know enough about these engines and engine swaps to make a good decision. I'm thinking that a stroker with compression around 9.4 and a poor quench height would work with pump gas if I use a longer duration cam to bleed off compression at low rpm and use the older style 4.0L spark plugs. If you think this will ping in offroad driving conditions, or would have bad emissions and/or alot of carbon build up (that could raise compression), let me know. What I'm wondering is what will the sideaffects be of swapping in this torque monster, i.e. will I need to worry about axle wrap, breaking d44's, cracking the frame, getting poor gas mileage, having too much torque for the available traction...etc. Will I feel a power loss with a stock 4.0L and 35" tires even if I regear? Basically I don't want the extra torque if it will break things or have ill sideaffects, as I can live w/o the extra power even though it would be alot of fun. I know I've kinda beat this to death, so thank you to everyone who has bared with me here (I must give Snitty credit for all of his usefull info on strokers). I think I'm alot closer to having the whole thing planned out now.
I would rather have a more efficient and well matched smaller engine than a few more cubic inches. I don't think you would go wrong either way for what you want the Jeep to do. A 4.0 can turn 35s like a champ, if the rest of the combo is setup to do so.
RE: DESPERATE... help please
where in oregon were you? Live there too? Dont worry bout breaking d44s with 35's..You'd have to be hammering pretty hard. I haven't in over 2 yrs w/ hard use.
Oil Leak
I live just south of San Francisco, but every summer escape to the Sunriver/Bend area of Oregon to get away from the hustle and bustle of the bay area, and California in general. I think one of the reasons I'd like the extra power of a stroker is I used to be a dirt biker and sort of miss the acceleration when cruising around on green circle dirt roads...don't know how a 4.0L would respond to the throttle, just that a 4.2L with 3:31 gears and 32's fell a bit short for acceleration and freeway driving. Also I'm wondering about the driveability of 35's on the freeway...I guess that a good steering damper and the wind noise will compensate for the handling/noise of the tires. Other than that, I just found an isuzu rear dana 44 with discs that is in great shape. Good to know it will hold up to 35's.
RE: Oil Leak
Glad to hear that Oregon is your cup 'o tea, GaryMB - that area is beautiful - give a shout next time if you wander over thru Eugene/Florence areas. LBR
