Amc used ford starters, silinoids, coils, ignition modules, and other stuff, (actually had a module go out in a late 80,s ranger "87" I think, had an extra for my 79 cj and used it, pluged it into the ranger and fired it up. the ranger had a swapped 302). have you tried the cj,s starter yet? I always thought the flywheels were either 168-158 tooth flywheel, but maybe not for newer cars. Is the bendix even hitting the flywheel? if so you may need to use shims on the starter to get the correct engagment. I was reading recently about starters as mine is out and cant find one (65,327) and while scaning over a post I seen something about newer flywheels with tone rings on them??????????????? didnt really read it as it didnt apply to me, but if that is true, might have something to do with it. I would think any ford starter for the correct tooth flywheel would work. I always thought the bellhousing had to match the clutch size used and the starter match the flywheel used?? I may be incorrect though.
