jtm703
Under hard accel from a dead stop, the rear end is making a godawful noise. Anyone else experienced this?
At first I thought it was just tire squeal, but it's too high-pitched and sounds metallic in nature. And I can feel a shudder at the same time. This noise is new...and I know my Jeep's squeaks and rattles very well.
Could this be a sign that a u-joint or axle is about to give way?
I did blow a tire on the trail this weekend (while climbing out of a steep hole) and it caused the xfer case to pop out of gear and all sorts of other drama. She ran fine, though, after getting the spare on and I was able to wheel out of the woods and go home with no issues.
She's lifted 4" with springs and has an xfer case drop kit, but all the running gear is stock and on 32" tires. Open Dana 35 out back.
