motobilt
Official Vendor
$409 Shipped!!!
334-699-6300
You are Buying a Adams Driveshaft Custom made 1310 Rock Crawler CV Driveshaft and a Rough Trail Sye Kit. This Kit only fits a 231 Transfer Case.
Adams Driveshaft sells more Sye Kits and Driveshafts in the Industry than any other Company.
Contents:
[1] Rough Trail Heavy Duty Slip Yoke Eliminator Kit
[1] Rock Crawler 1310 CV Driveshaft
[1] Set CV Bolts
[1] Free Adams Driveshaft T-shirt. Sizes to choose from: M, L, XL, XXL, XXXL, XXXXL
We will need you to e-mail us or call us with the following information:
YEAR, MAKE, MODEL, LIFT SIZE, DIFFERENTIAL SIZE, T-SHIRT SIZE
Although we do know most of the driveshaft measurements, there are some we don't due to different size of lifts, belly up's, differential changes, and extended wheel bases. If for some reason we do not know the measurement then we would have to send you the sye kit first and then have you get us a measurement. You can call us first before you buy to make sure we have your measurement if you absolutly need both at the same time.
Warranty Information
SYE KIT: Lifetime Warranty against any Defects. No Warranty if broken by accessive torq, or abuse. Seals are a wear item and will only have a one year Warranty.
DRIVESHAFT: Lifetime Warranty on the Welds and Tubing if you break do to torq. No warranty if components break due to bad angles. U-joint and CV Kit are wear Items and should be greased about every three months or three thousand mile wich ever comes first. No warranty if u-joints are not maintained properly.
$409 Shipped!!!
334-699-6300
			334-699-6300
Contents:
[1] Set CV Bolts
$409 Shipped!!!
334-699-6300
