jeeperwilly
Laser cut 1/2" thick mounting plates for making rear TJ bumpers. Mounting holes are 1/2" in dia which gives a little wiggle room for deviations in the each frame. Requires 7/16" mounting hardware.
$15 per pair
Approx. 10 pairs available.
Ships USPS flat rate. Not sure if a pair will fit in a flat rate envelope but they will in a flat rate box. Shipping will be no more then $13 to lower 48.
I also have several pairs of my "No pull through" pull points. They will work with any 2x? box material. You can see them above in the 2x4 rear bumper. Cut from 1" thick steel and accept a 3/4" clevis.
$30 per pair
$15 per pair
$30 per pair
