T-Case in neutral AND transmission in gear for a manual and park if you have an automatic.
xt_master...I believe on the TJ, On a dolly If you were to leave the t-Case in gear and the tannsmission in neutral, you'd want to disconnect the drive shaft, or the transmission won't be properly lubricated.
