What Power Sterring box to go with.
Jordan
RE: Which GPS?
I have a 78 cj7 with a 3" lift and 33" tires and want to get rid of the manual sterring. I already have a pump that the last owner installed so i need to know what i can go get at the junkyard and bolt on.
Also will the stock sterring shaft work or do i need something else? if so what.
I'm pretty sure that you will need a different steering shaft. I'm not sure about what donor steering boxes you could use, though.
