TwistedCU
Active member
NEED Help on 2 part problems.
I'm not sure what's causing it, but I'm getting a pretty loud whine from under the hood. It is definately not the transmission ot transfer case, because it does it idling and increases speed/pitch when I give her a little gas. At first my thoughts were that I screwed up a main bearing, but I'm pretty sure now that it's toward the front, like the clutch fan or water pump. I just canged the oil and it looked pretty clean. I'm not sure what I got here...???
