I am new to the forum here and am having a heck of a time sorting out my MC2100. I recently acquired a jeep on trade and it was barely running with the factory carter carb, I thought this would be a good opportunity for a swap to a MC2100 since everyone raves about their simplicity. I took a stab at the float height, set it with the carb flipped over to about 1/2" from the flange. Installed some #47 jets and adjusted the idle screws to two turns out. It started up, and won't stay running. It will continue to run above 1500 rpm and sounds pretty good there, but it won't come anywhere close to idling. Runs rough then dies out, I've also had a few backfires through the carb. I have a power valve save installed so I'm hoping that worked. The electric choke is hooked up and appears to be working (slowly opening after a minute or so). I will try and put a timing light on it today, with a HEI is should be 8-9 deg at curb idle correct?
Any suggestions?
Any suggestions?
