RideRED258
I have an 89 YJ with a 4.2L. I ripped off the stock carb and replaced it with a TBI unit from Howell. Ever since it has been running a bit hot. I took out the stock 195 thermostat and replaced it with a 185. Its a new engine, with all new temp sensor, sending unit, water pump, ect. The problem is its not registering that hot on the gauge. It reads normal, but i checked the oil and noticed the paint bubbling off the valve cover. I checked the plugs which had a burnt white reside with blistered insulators. Im not sure if It is running lean, and if so, shouldnt the computer adjust the mixture accordingly(the Howell kit is computer controlled. Its off a 4.3L chevy)? Im not sure where to start, as the gauge reads normal, but bubbling paint and blistered plugs dont lie. Shes running hot! Any advice would be great.
