You might be a redneck if ........
If your half doors are made out of plywood with house windows so u can have sliding windows
You might be a redneck if you have almost a complete Jeep in spare parts that is nicer that the one you drive everyday.
If you need a wrench and you look in your Jeep before you look in your tool box.
If you have used a bic lighter for a dash light.
If a hammer has been involved in several "fixes" on your Jeep.
you keep your old parts in the back of your jeep to put back on if the new parts from autozone fail.
Well this is self explanatory
You might be a red neck if you use Pringles cans and PVC piping to build a primitive , but effectively efficient water forwarding device to keep your jeep from drowning. Kudos ! Rednecks ARE blessed ! Hold on to your Dixie cups , the South gonna rise again ! ( Willie Nelson )
...if your too long glasspack melted your upper control arm bushing and this was your fix cause you can't afford $40 for a new muffler
It's now 7" shorter with a turn down made from a piece of straight pipe.
More of divorced father with a mortgage ingenuity...but at least I have neet toys to play with at work.
I respect that . Respecting your priorities to responsibility and making due as well . Best of luck to you brother. Greg
You might be-a redneck if you have enough OE parts from upgrades to rebuild the stock jeep
You might be a redneck if your tire inflation is comprised of lighter fluid and a match
YOU PROBABLY ARE A REDNECK IF...
People stop by your house and ask if you are parting out that wrecked Jeep, and you reply, "heck no, that there is my daily driver."
You might be a redneck if you change rear gear oil more often than engine oil.
