Howdy from Oregon gang,
Well, when I first got "Betty" the horn didn't work at all. Popped the hood and I found the reason why........... no horn. I had a spare electrical horn from my bike so hooked it up and it worked........only too well.
A slowly creeping problem is the horn keeps honking after I let up on the horn button, that is becoming much more frequent. So I disconnected the horn and it'd reset, as I had more pressing issues, this kinda fell by the wayside.
This grant steering wheel is one of the newer items and I've carefully checked and re checked that the trouble wasn't with the horn buton itself. With the horn connected and I start the motor the horn doesn't honk. However, when I press the horn button briefly the horn honks even after the spring raises the button. The button is fully raised making no contact with the column. When this horn blowing has been going on I've removed the horn button and spring, but it makes no difference.
Now that I'm ready to diagnose again I'm thinking possibly a stuck relay, but I thought that a stuck relay would leave the circuit open, am I correct? or should I just replace the relay?
Thanks and a lift of the lynch lid for any responses
