Steering knuckle bolt thread reapir
RCJP
Hi recently i changed my disk brake rotor, and pads. and to my suprise one of the bolts that holds the caliper to the steering knuckle was missing!!.
also when i tried to put the other one in it never tightens, so I have an issue the threads.
So has any one tried to repair the threads on a Steering knuckle?
I heard of a guy that re-did the threads to the next available bolt size
any Ideas before I need to put down the money for the overhall of getting another steering knuckle?
heli-coil back to original size, done several. Good luck, Ron
Hi Thank you I heard like 3 options.
The heli-coil,
get the next bolt size ( this means more work)
Also to try a longer screw with a nut at the on the brake-pad size. Have you tried this before?
I would not use a bolt and nut.
I highly recommend using a helicoil. They're a little expensive but it will be a strong fix.
Or replace the steering knuckle.
[Also to try a longer screw with a nut at the on the brake-pad size. Have you tried this before?/QUOTE]
Bad Idea I done that on my xj nut backed out and caliper let go , $100's of dollars in damage and get this it was a lock nut , FYI the heat from braking melted poly inlay in nut and all hell broke loose
Helli-coil or replace the knuckle way cheaper than creating a disaster like I had
BETTER SAFE THAN DEAD
Hi thanks for the reply... I looking at inserts Helicoil and Thread Repair but Icant find a table so I know the exact measure of spring to buy, I went to a a Shop and they only had the full kit that is a $100+ they did not have the single package I looked in the net found those for around $25 But not sure about the measurments fot the tap and drill the caliper bolt is a 10mill I was told
what size have you bought
M8-1.25; Car Quest near me has them as does Fastenal, Grainger and such; if u were nearby I'd say cmon by; I have a few left over from the same repair on my XJ. it ain't rocket science.
Hi to all... the final thing was inserts. but not the helicoil kind. and since I hade a ripped boot I end it up taking the entire thing of.. but it was fixed. Felt great when I was done
thanks for the help. :)
picture of knockle with "silver colored" inserts on the top side of pic
and where i took it of from.
I bought a helicoil kit at Napa, had never done a helicoil before. It went a lot easier than I thought, did not have to take knuckle off to drill/re-size hole. M8 1.25 is a pretty small bolt for this type off application, too bad they didn't start with something bigger.
