On your Jeep, the ball joints are responsible for connecting the steering knuckle to your axle. A worn ball joint will often cause sloppy steering and a popping sound as you go over pot holes and bumps. A simple check to see if your ball joints are bad is to jack up your Jeep, with a few inches of air under your front wheels. Use a long pry bar or broom handle inserted under one of the front tires to move the tire up and down. While the tire goes up and down, you may see movement in your ball joints. You should not see any movement.Here is an example of a bad ball joint:
and another (with the boot removed)
Once you've identified your ball joints as bad, you'll need to go about replacing them. Replacing ball joints requires a ball joint tool (inventive name huh?). This is a C-clamp with some extra fittings that allow you to press out the old joints and press the new ones in. I rented my tool from Advance Auto Parts for free (leave a $160 deposit, and then get it back when I'm done).
You'll also need a standard socket set, a floor jack, a grease gun (to lube your new ball joints), and some jack stands to secure everything.
Optional, but recommended:
There is a Jeep / Dodge specific ball joint tool (OTC 7894) that is available at amazon:
Amazon.com: OTC 7894 Ball Joint Service Adapter for Jeep/Dodge: Automotive
This is used with the standard ball joint tool that you rent at the local parts store. What this does is give you a tapered cup. The Jeep knuckle is angled, so that if you use a universal ball joint tool you'll end up putting the ball joint in at an angle. In the photo below you can see the ball joint on top, then the knuckle below it, and the angled cup on the bottom.
