Jeep Wrench
Hi gang,
I'm new to this site and hope I can rely on your knowledge for these items:
I just bought a 1998 Cherokee that had a few issues. I've fixed the major problems but want to correct these as well.
1. The overhead console lights do not operate. Do these bulbs all run off a single fuse or is there a relay involved? Also, the only courtesy light illuminating is the one beneath the dash when the door is open. I'm assuming the rear courtesy lamp or console light(s) should light as well.
2. The driver's side door was pryed open in an attempt to steal the vehicle which damaged the opening mechanism from the outside (the inside opener operates fine) To open the driver's door requires a trick of depressing the button, pushing the door inward and then pulling. It appears the outter linkage needs more throw to completely unlatch the door. Has anyone dealt with this issue? If so, how is it adjusted? I've tried moving the latch in a different directions but it didn't work.
Thanks in advance for any useful information. I've purchased this as a fixer-upper so don't care to buy a manual as I plan on selling it soon.
Bruce
Bruce
