Last person to comment wins $20
I like this one better.
You are driving in a car at a constant speed. On your left side is a 'drop off', (The ground is 18-20 inches below the level you are traveling on), and on your right side is a fire engine traveling at the same speed as you. In front of you is a galloping horse, which is the same size as your car and you cannot overtake it. Behind you is a galloping zebra. Both the horse and zebra are also traveling at the same speed as you. What must you do to safely get out of this highly dangerous situation
Lock up brakes, takes out zebra, fire truck and horse blow by. Flip a 180 drive opposite way up and over zebra... Buh-bye! ?de04?de01?de1c?de06?de1d?de09
Not quite. There is a much less violent solution.
