98 cherokee zj no start conditions
Mikentina
I was driving one day to oic the wife up at work when jeepie decided to act up ......she started to spit and spudder than she backfired amd shut off all happend within 50 yards....so i tried to fire her back up and she said f*** you not today....so i bought parts.....lol i know what a idiot.....parts list....crankshaft position sensor camshaft position sensor distrubator cap and rotor plugs and wires and a ignition coil o plus a fuel pump and filter and she still wont start also my scanner told me this today pics below
For some reason your pics didn’t load.
I can see them.
They show up as broken icons in the iPhone app.
But I can see them via PC web. Jeeps.com
Ok guys so i did reset the pcm and changed thise parts due to a no start condition and at this time she still dont start
Check fuel pressure key on. Check spark. By not start you mean the engine turns but it doesn’t catch.
Does it even sputter?
Ok I realize I didn’t ask. The sensors you replaced. Were they OEM?
Aftermarket CPS and CKPs are often bad out of the box. One big issue is the CKP not having the paper gasket. Without the gasket the sensor gets inserted too far, The result is the flywheel killing it on the first crank of the engine.
