Greetings from new member in the UK with temp sensor question
fenns
Hi all - forgive the brevity of my first post but I really need to get home and see my family.
I am a recent XJ convert having inadvertently saved a 1996 Limited 4.0 from rotting on the street - a long story; perhaps for another time :lol: Being a UK vehicle it is right hand drive - like your US mail model.
My question concerns the coolant temp sender located at rear of the engine block - the one that feeds the temp gauge (not idiot lights) . If I am able I will post photos to assist identifying.
The male (?) connector has stated to breakdown (1st & 3rd pic shows the sensor removed from it's grey housing) due to age/heat but I have managed to jury rig a repair that sees to work .... for now anyway (see 4th pic). At some point I will need to replace both the temp sender & most importantly, this connector, but have failed to find a supplier.
Can any one assist as I'd like to buy both temp sender, connector plus the coolant temp sensor (the one in thermostat housing) together?
Ideally I go for Mopar, Crown or Standard parts.
Thank I advance for any advice/assistance offered.
Simon
I cannot help on the connectors but wow, those really are breaking down. you might have to try just searching for automotive wiring plug, or something like that in google
Hello from a fellow Brit. exiled in Spain. My best suggestion would also be Rock Auto, I have a 1994 XJ and manage to get a lot of stuff from them. You have to watch out for import duty as it inflates the price by quite a margin.
Since you did the post you have probably got it sorted by now. It's been a long time.
I order most of my stuff from RockAuto as well. How expensive is it to have parts shipped to Spain? I usually spend $15 or so to have it shipped inside the US.
