1979 CJ7 Quadra Trac - With a Chevy 350 Vortex Motor- Need radiator
The URL is the web address you see in the top of your web browser. Usually starts http//www. Or https//www. This is used if you copy a pic from the web or if you uploaded it to a share site like photobucket.
You should also be able to upload the pic directly using another function. It was on the PC version of jeep website. In the tool bar of the reply field you click the add pic icon that looks like a pic. On the top of that there are two tabs one for website and one for from a file. Use the from a file. Brows for the pic file and load it.
Regards,
JPNinPA
Sent using TapTalk
JPNinPA, I tried to load the pic again following your directions and it didn't work.. My daughter tried it also with no luck, she said we are doing it correctly and it should have loaded it. she doesn't know why it didn't. she had to go to work so she said she will try again later. sorry, will get it up asap. Probably wont need it by then lol.
Looking were to get a Radiator /aluminum /and electric fans for a Chevy 350 5.7L vortex and TH400 transmission /quadra trac
that i am installing in a 1979 CJ7 quadra trac Jeep
Restoring the entire jeep 1979 CJ7 Just changing the motor.
Any info will will be greatly appreciated
I will post picture as i keep going thx
Started with a Full running Jeep - Frame was Rusted - Replace the Frame with a none rusted one
sand Blasted it and Put Por15 on frame and axles, Has Anybody Used a Fiberglass Body we are in the north best and want to avoid rust
Motor in the work
update of picture
Coming Along still working on it
Motor in the work
Update
