Hello I am new to the Jeep thing. I recently bought a 1997 wrangler tj with the 2.5 inline four cylinder. It has been sitting for several months due to it not starting. It will crank all day long with no start. I’m not getting power to the fuel pump. I have tested the pump and it works fine. I have tried troubleshooting electrical. I’ve tested and checked all relays and fuses. No blown fuses and the relays test good. Also my voltage gage, fuel gage and radio are not working. Not sure if this is related or if this stuff was just not working before. Also my wipers will not shut off once turned on. Not sure if this is related. You have to turn the key off and reset. I ended up pulling the fuse for the time being. As far as I know everything else seems to be working fine. I also order a new crank positioning sensor. I have not gotten it yet but Iv read that this can be the issue for some I pulled the old one and it definitely did not look right. The end close to the wires appeared to be melted.
any help would be greatly appreciated.
