derff96963
crank position sensor
I have a 2000 XJ with 4.0 I6 with a KNN FIPK. Other than that the engine is completely stock. What I don't like is just recently it doesn't idle very well. Its does idle and has never stalled on me but I just don't like how it idles. The other day I was stuck in traffic in some road construction and after about 5 minutes of not moving it started shaking pretty bad. Again it did not stall and it revs fine and has lots of power. I have checked and cleaned the throttle body and the check engine light is not on. I have changed the spark plugs with no change. I cleaned the IAC valve and it does seem to operate nomaly and the TPS tests ok to. It only has 61,000 miles on it. Anyone have this problem or have any ideas?
