When you start my jeep it runs good now but when you drive it after about 5 mins it just dies. I will let it set about 5 mins and it starts back up and I can drive it for about 4 or 5 mins and it dies again. I have replaced carb, fuel pump, coil, plugs, distributor cap, and button, Ignition module. I have done compression test and it was fine I am gettn fire to all plugs and checked fuel presure and it is fine. I have no cat so I know it is not stopped up. Could it be the distributor that is the only thing I have not replaced???
