brake lights not working on my '94 Cherokee
TonyInKS
I've got a '94 cherokee and the brake lights stopped working, I've replaced the bulbs and the brake light switch, and they're still not working, any ideas?
Yeah, I went through and pulled ALL the fuses from the fuse block, and they all appeared to be good. I've never had electrical problems before, and now I see why they suck, how likely is it that they gave me a bad switch?
Or use a test lamp to see if the supply circuit has battery voltage on it. If it does, press the brake pedal then check the signal circuit to the stop lamp. If it lights up, check the harness to the rear.
