1068767
The IAC motor (Idle Air Control) is on the passenger side of the throttle body. I'd recommend disconnecting all the sensors and removing the thottle body that is held on by 4 bolts, real easy to do. Remove the sensors from the throttle body and give the throttle body a real good cleaning with carb cleaner and a toothbrush. Put it back together and you should be fine. The IAC sensor may need replaced, but try the cleaning first.[addsig]
