GaryMB
I'll be needing to know what pinion angles to set when I install my dana 44's in my CJ; I know that I'll need a CV for the rear to accomodate my 4.5" lift, which means pointing the pinion strait at the T-case. What about the front, though? Do they often require CV's like the rear does (I'm hoping to be able to use 4x4 at high speeds for going up to the mountains in the winter)? Also, I'll be doing a shackle reversal, so the front shaft will need to be able to compress/extend more than the stock one. Any ideas on what pinion angle to set in the front, and any suggestions on where to get driveshafts besides the local driveline shop?
