There is something else to try. I need to dig it up. But I recall someone with a similar issue a few months back. There is a trans module that can be reset. Or it could be the torque converter.. I'll post back if I find it.
But, Being your neighbor took the readings he should be able to tell them to you. Otherwise drive to AUto Zone or OReilly's and ask them to borrow the gauge to perform the test. Here is a procedure. The only discrepancy is pressure is 59 +/- 1psi and not +/-5.
"DESCRIPTION The fuel pressure regulator is located within the fuel pump module. It is serviced by replacing the fuel pump module assembly.
1. FUEL PUMP MODULE NOTE: Before continuing visually and physically inspect the fuel delivery system for external leaks or damage. Repair/replace as necessary. WARNING: The fuel system is under a constant pressure (even with the engine off). Before testing or servicing any fuel system hose, fitting or line, the fuel system pressure must be released. Failure to follow these instructions can result in personal injury or death. Turn the ignition off." Pull fuel pump fuse or relay. Start engine and run until pressure drop causes it to stall. 1min or less. Replace fuses and relay. Repeat this in the end to remove the gauge components"Install special tool #6539 (5/16") or #6631 (3/8") fuel line adapter. Install the fuel pressure gauge. Start the engine and allow the fuel system to reach maximum pressure. Turn the ignition off.
NOTE: Fuel specification is 407 kPa +/- 34 kPa (59 psi +/- 5 psi).
Using special tool #C4390, Hose Clamp Pliers, pinch the rubber fuel line between the fuel pressure gauge and the engine. Monitor the fuel pressure gauge for a minimum of 5 minutes.
NOTE: The pressure should not fall below 241 kPa (35 psi)
Does the fuel pressure drop? Yes - Replace Fuel Pump Module.
No - Go To 2
2. FUEL INJECTOR(S) WARNING: The fuel system is under a constant pressure (even with the engine off). Before testing or servicing any fuel system hose, fitting or line, the fuel system pressure must be released. Failure to follow these instructions can result in personal injury or death.
Remove special tool #C4390. Start the engine and allow the fuel system to reach maximum pressure. Turn the ignition off.
NOTE: NOTE: Fuel specification is 407 kPa +/- 34 kPa (59 psi +/- 5 psi).
Move special tool #C4390, Hose Clamp Pliers, from between the fuel pressure gauge and the engine to between the fuel pressure gauge and fuel pump module. Monitor the fuel pressure gauge for a minimum of 5 minutes.
NOTE: The pressure should not fall below 241 kPa (35 psi) Does the fuel pressure drop?
Yes - Replace the leaking fuel injectors.
No - Test Complete.
1. FUEL PUMP MODULE NOTE: Before continuing visually and physically inspect the fuel delivery system for external leaks or damage. Repair/replace as necessary. WARNING: The fuel system is under a constant pressure (even with the engine off). Before testing or servicing any fuel system hose, fitting or line, the fuel system pressure must be released. Failure to follow these instructions can result in personal injury or death. Turn the ignition off. Install special tool #6539 (5/16") or #6631 (3/8") fuel line adapter. Install the fuel pressure gauge. Start the engine and allow the fuel system to reach maximum pressure. Turn the ignition off.
No - Go To 2
No - Test Complete."
Regards,
JPNinPA
Sent using TapTalk
