paradineai
I am needing help with my jeep lights.
it has the fog and auto options
i need the pinout and wire diagrams for this
i work nights and need my car to work
the problem came quick
i was working and sitting on side of street holding brake pedal while in reverse and had headlight switch in auto mode (as i always do)
my dash lights started to flicker/dim and once i started going the dash lights went out and so did my running lights
but yet when i press brake pedal they come on again while holding it (for the first 5 minutes) then after this they no longer came on at all and now the dash lights flash with my hazard lights but my running lights still do not work
even with all of this my low/high beam headlights still work fine
i have tried using manual mode on the switch but still nothing
just before this problem came up i smelt a burning smell that only lasted for about 1-3 minutes
(please tell me this is a simple fix and that i dont have to take entire dash out again)
edit: went to work last night and headlights no longer work unless in manual mode, i ended up crossing the running light wire (DB/RD) with the headlight wire (TN/??) just to get my tail-lights to work
